4th gen posi carier in third gen
Old May 18, 2004 | 10:48 PM
82camaross's Avatar
Car: 82 camaro z28
Engine: 305 lg4
Transmission: 4 speed
Is there anyway I can put a forth gen posi carier into my 82 10 bolt. Or can I make it work if I modify something. Please help, thanks.
Old May 18, 2004 | 11:50 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
It will fit fine. 100% bolt in deal. BUT your 1982 rear end has 26 spline axles. You need a set of 28 spline axles from a 89-92 car.
The "slp" posi's everyone talks about are actually take-off posi units out of 4th gen camaros. 82-02 had the same rear-ends pretty much. Except the 4th gens are slightly wider...
Old May 19, 2004 | 05:53 AM
ede's Avatar
ede
only problem area you may run into, besides axles, is the series of the gear set and the carreir series. with a little luck and clean living all you'll have to do is swap the ring gear over to the new carrier.
Old May 20, 2004 | 01:05 AM
Endi5oo's Avatar
Car: Firebird/Trans Am
Engine: 305 TBI
How easy would it be to put in a 4th gen rear end with traction control?
Old May 20, 2004 | 01:56 AM
Transmission: 4l60e
The rear-end is a direct bolt in. But I don't think you could make the traction control work.
Orr89RocZ
Apr 25, 2016 08:28 AM
Orr89RocZ
Oct 7, 2015 12:47 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
