Is a T700 from a 1989 the same as a 1986
Old May 19, 2004 | 05:07 AM
STEVE OC's Avatar
HiGuys
I have been offered a T700 auto trans from a 1989 Camaro that was a Jap' export and want to know if it is the same transmission that was used in a local U.S 1986 Camaro IROC , if not what do I need to do to make it fit and operate , Can you offer any help
Thanks Steve [ From Australia ]
Old May 19, 2004 | 05:40 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Externally it is the same. There are a few slight internal differences. But it should fit.
Assuming of course that the 89 car is a V8. A 6-cyl trans won't bolt to a V8.
Old May 19, 2004 | 06:05 AM
STEVE OC's Avatar
The car is a 305ci V8 do you know what the difference is betwwn a 1986 and a 1989 Steve
Old May 19, 2004 | 08:11 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The number of splines on certain parts, stuff like that. Nothing that affects whether it fits or works.
Old May 19, 2004 | 03:27 PM
STEVE OC's Avatar
Thanks very much for your help , I will go ahead and buy it , has only done 37K km about 23K miles, should be like new, i will have it beefed up and then fit it later , it will only be used as a daily drive car what mods can be done to make it better
Thanks Steve
Old May 19, 2004 | 11:16 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
If anything it is a better unit (1989) than the other one (1986)... Both of them use a 30 spline input shaft, but the 1989 has extra goodies like an auxillary valve body, and extra updates to improve lubrication and life-span of the transmission..
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
SRKLEGIN
Oct 29, 2015 06:38 PM
wanext
Oct 6, 2015 12:18 AM
Gordonr1973
Sep 29, 2015 11:59 AM
