Transmission rebuild question
Old May 19, 2004 | 08:10 AM
Luther6704's Avatar
Car: 1986 Iroc
Engine: 305 TPI w/30,000 original miles
Transmission: 700r4 Transgo Shift Kit
The torque converter blew and sent metal shavings through the pump. We didnt have a pump on hand so we ripped the transmission out of an 87 suburban. The pump was set up for an auxilary valve body whereas my 86 iroc's was not. We simply blocked off the aux vb passage. Was this adequate?
Old May 21, 2004 | 01:07 AM
Pro Built Automatics's Avatar
Yes, that can work. The problem is, if the TC came apart the metal went into the cooling system and most likely in the the transmission. In most cases when a TC comes apart, it takes the transmission with it.
Vintageracer
Jan 10, 2020 05:33 PM
Cleotiz
Jan 6, 2018 08:56 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
formula_novice
Aug 18, 2015 08:48 PM
redmaroz
Aug 16, 2015 11:40 PM
