Need info on Swap
Old May 21, 2004 | 08:31 PM
86camedcamaro's Avatar
Transmission: 350 turbo
Need info on Swap
ok i gotta 86 camaro with a v6 i am converting to a V8 and 350 turbo tranny i already put a posi rear in it with 373's umm my question is what do i all need to swap the 350 turbo tranny in its outta 80's truck with a 9'' tail please let me know and about motor mounts to i didn't know where to post this..
Old May 21, 2004 | 09:46 PM
scubas_90rs's Avatar
Car: 90 RS, 83 z28, 85 ranger
Engine: none, 350, 2.8
Transmission: none, t-5, 5-speed
all you should have to do for motor mounts is just get you some v8 mounts. your crossmember should take them.
Old May 21, 2004 | 10:28 PM
Z28guy83's Avatar
Car: 83 Z28
Engine: 400sb
your gonna need the torque arm relocation bracket and the tail shaft that will accept the tourque arm bracket and the driveshaft from a 200 metric trans cause the 700r DS is shorter
Old May 22, 2004 | 09:18 AM
i mean if i use a long tail 9'' 350 turbo tranny and the B&m relocation bracket i can use stock Drive shaft right?
Old May 22, 2004 | 04:19 PM
Z28guy83's Avatar
Car: 83 Z28
Engine: 400sb
itll tell you in the instructions that come with the torque arm relocation bracket but you definately will need it
Old May 23, 2004 | 12:17 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
When you use the 9'' tailshaft th350 you will just need the torque arm mounting kits...or a spohn crossmember/torque arm.
You can use the stock driveshaft and the stock crossmember when you use a 9'' th350.
AussiePr0nCar
Mar 6, 2020 04:04 PM
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
