Governor Gear removal....
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
I read what everyone posted on the GG removal but had no pictures to steer me. Here's a few from my old tranny.
Jim.
Ooops, pictures wouldn't post. I'll try again tomorrow.
Jim.
Car: '86 Trans Am
Engine: LG4
I had just changed it about 5K ago, before leaving San Diego. I guess with the tranny imploding, it changed it to a darker color.
Jim.
Jim.
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
removing the GG does what?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Gives you access to change the weights and springs so you can change the shift behavior.
And Also if your Transmission is not shifting you may want to check that Gear out also.. Remove Pin and remove Gear.. I believe the proper Gov. is important to the 700r4's potential.. If you have or had your trans built you would want to start off with a No Tab Gov. Esp if you have gears.. And if you have really Jacked up the pressure This Gov and correct spring rate will work Best.. I'll try to get some pictures of a No Tab Governor that has been Modified..
UltRoadWarrior9
Sep 2, 2015 08:24 PM
