tranny flush?
Old May 24, 2004 | 02:01 PM
Kaas's Avatar
Car: 89 Iroc-Z
tranny flush?
Alright guys, i was checkin the tranny fluid in my car, and it looks like it's time to do a flush on it...i have a 700R4 and was wonderin how hard it is to flush out the tranny, and what all it consists of? i am also wondering about putting synthetic fluid in it when i refill it up...
Old May 24, 2004 | 03:39 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
You can't technically flush the tranny yourself on most cars. Your are supposed to take it to a shop where they hook up a machine and it does it. The only thing is, for our cars, you can flush the tranny yourself. If you want all the details just ask and I'll post it.
It would probably be a good idea to put in a new tranny filter and gasket since you're probably going to have have all new fluid in your tranny (if you flush it). Another good idea is to install a drain plug kit in your pan. I did and I love it. I haven't used it yet but it makes things a whole lot easier in the long run.
Also, I'm not really sure if it's a good idea to put synthetic fluid in there. There are always HUGE debates about regular vs. synthetic fluids. I would probably just stick with regular, though, since your tranny probably has a lot of miles. Just put in whichever you want. It's not really going to hurt it either way.
Old May 25, 2004 | 12:28 PM
Kaas's Avatar
Car: 89 Iroc-Z
would it be more hassle than what it is worth to do it myself? altho i would really like to learn how to do it myself, if i can take it to a shop and have them do it for under 60 or 70...
Old May 25, 2004 | 05:23 PM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
It's not a huge hassel to do it yourself. You can get a filter and pan gasket kit from the autoparts store. I would also suggest sticking with regular Dextron 3 sicne that's what it is running now. I run the Advance Autoparts brand stuff myself and it works just fine.
Old May 25, 2004 | 06:54 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The process in 12 easy steps:
http://www.amsoil.com/faqs/faq8.htm
I'll never use "regular" ATF again. Synthetic is so much better, it doesn't make any sense to risk a $1200 (or more) transmission over a few dollars. If your tranny is on its last leg, that's a different matter - fix it and then fill it with synthetic.
Old May 25, 2004 | 07:08 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
With the 'home-made flush', it works because when the cooler line returns the fluid to the transmission, it just dumps the fluid back into the pan. That's why you can unhook the fluid return line- because you're pouring new fluid into the trans pan, and keeping the trans pan full.
I'd actually like to change those directions a bit, but it means more work. The best spot to unhook the cooler line is not at the trans cooler (passenger side of radiator), but from the transmission itself- and you want to unhook the RETURN line.
If you just unhook the line at the cooler, you're not getting that extra bit of old fluid out that will be in the cooler line that remains connected.
But disconnecting the line at the trans is more work... it's a tight fit with a wrench up there. Before you crack a fitting open, clean the area around the fitting first so dirt doesn't drop into the trans.
And one more tip since it's your first time... when you get the old filter off, take a pair of angle cutters (or pliers or a screwdriver or Whatever) to it, and cut the filter apart. Inside is the filter medium, folded in half. Unfold it- and look for large chunks of metal. There might be small pieces... but if you have large piles (like I did), better start saving for a rebuild!
sheachopper
Jul 31, 2019 11:27 AM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
mfp189
Sep 27, 2015 09:25 AM
IROCZ1989
Sep 4, 2015 11:54 AM
