U-Joint Removal Problems
Car: 87 Formula Firebird
Engine: 5.8Ltr 356
Transmission: WC t-5...... probobly go boom soon.
any advice on how to get out u-joints without a vice or special tool? or an oxycetaline torch? and ideas would be really helpfull
Car: `86 SS / `87 SS
Vice or a press.
I believe even the factory injected plastic retainers will require you to push things out with some good force.
Anything too unique in method and you might risk tweaking the yoke.
Engine: 5.8Ltr 356
i did it with a block of wood, some liquid wrench, a hammer, and a old taiwan socket. Thanks guys
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
ok i see there is some force required to get these things out however what is the procedure to get them out. try to tell it to someone that hasent a clue how to do it....which side do i try to press out and do i need to take those caps off one of the ends? i saw some type of metal clip too between the cap and ujoint, how o i get that off?
