Rearend info
Old Jun 2, 2004 | 12:34 AM
Rabbitt's Avatar
Car: 1987 Iroc-Z
Engine: 355
Transmission: 700r4 w/ about 7500 miles on rebuild
Rearend info
I Just bought a 1987 Iroc-Z.. I need to know ALL the information i can about the rearend. Where can i look to look up the stamped #'s and all that. I need to know size (7.5 or 8.5 or whatever) and 9 or 10 bolt.. I would just like to know i can tell
Old Jun 2, 2004 | 04:31 AM
ede's Avatar
ede
get under the car and look, then you'll know what you have. you can look the stamped code up in your manual or rpo decodes.
Old Jun 2, 2004 | 06:23 PM
DoBeR's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Transmission: 4 Spd Auto
For starters you can look underneath and count how many bolts are holding the cover on the rearend.
Old Jun 9, 2004 | 10:26 AM
JA_Formula_89's Avatar
Car: 89 Formula
Engine: 5.0 TPI (F-Code)
Transmission: 5 Speed Manual
If its a 9-bolt and hasn't been messed with...
Limited Slip - will have a metal tag at the (4:30 clock) position.
Gear Ratio - Will be stamped on a tag at (9:00 clock) position.
Use a wire brush to clean it up. I'm not sure on the 10 bolts.
Old Jun 9, 2004 | 10:37 AM
91formulaSS's Avatar
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
If it's a 10 bolt look on the front of the drivers side axle tube. You should find the axle codes there, somewhere under the rust.
Fanatic1074
Oct 3, 2022 05:57 AM
3rdgenparts
May 21, 2016 11:50 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
