Governer or Tranny
Old Jun 2, 2004 | 05:55 PM
Fastcam's Avatar
Car: 1986 Z28
Engine: 305 LG4
Transmission: 700 R4
Governer or Tranny
My car has almost 100,000 and the tranny stoped working the last month tryied adjust every thing and nothing! So i finally decided 2 get rid of it and get a new one. When i finally took the Tranny out i heard about the governer. I took it out and it was gone!!! I mean no teeth and cracked in 2!! I couldn't find the other piece of it. Now my question is Should i get my friends tranny from his car that i think was rebuilt not 2 long ago and install a transgo shift kit? Or should i put my tranny in which shifted hard in second and put the trans go in that and hope it works??? Thanks alot!
Old Jun 2, 2004 | 08:18 PM
Guest
Guest
Posts: n/a
well that pic right there would explain why your trans won't work... what i would do is get your friends trans and putt he transgo shift kit in it and then take your trans get a new gov. and keep it in case you blow a trans again
but if you need your car now and gon't have the cah doe the shift kit just put in a new gov. and it will work just fine.
Old Jun 3, 2004 | 02:08 PM
Pro Built Automatics's Avatar
The governor gear is gone from what I can see, and replacing it is not expensive. The choice is yours.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
