700R4 knocking?
Old Jun 2, 2004 | 07:49 PM
xeroxed's Avatar
700R4 knocking?
im just wondering if anyone else has had there 700R4 start knocking when the cars just idling but be fine under a load. seems like my cars given me nothing but problems since the day i put it on the road. besides the knocking noise i lost OD. i think its finally time to do that auto to manual swap ive been wanting to do.
Old Jun 3, 2004 | 10:24 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
First thing to check is loose flexplate to torque converter bolts. Get the car up in the air, remove 4 bolts for the cover, check the 3 converter bolts. You'd be surprised how often it happens, especially if anything has been done to the car.
It could also be the torque converter itself.
I've had both happen to me, although the converter tended to be quiet at idle and rattled/shook at higher RPMs.
Old Jun 3, 2004 | 01:45 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Could you go into a little more detail of what type of knocking you were getting from it. Reason I ask is before I swapped to a T5, I had a knock similar to a rod knock at a tad over 3k from time to time yet with the same engine and the T5 no noise at all. Nothing was loose and I was figuring it might be the tq converter going but Ive never heard one go bad in that manor.
Old Jun 3, 2004 | 03:51 PM
five7kid's Avatar
A rattling that would build up and diminish in a cyclic fashion with a period of a couple of seconds. Would shake the entire car. Under power, it would tend to go to a steady shake. The shaking was so bad, it loosened up the bell housing bolts.
I never found out exactly what was wrong with it, but the donor car had been rear ended hard, and I suspect it was damaged internally in that incident. When I did the mods, I got a remanufactured higher stall converter and traded it in.
Old Jun 4, 2004 | 03:28 AM
xeroxed's Avatar
the knocking im getting is pretty close to a rod knock. im pulling everything this weekend and hopefully ill find nothing wrong with the motor. the only thing i find strange is i lost OD and the trans oil isnt even burnt. its still bright red and dont smell burnt.
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
92projectcamaro
Sep 29, 2015 07:07 PM
efiguy
Sep 27, 2015 01:30 PM
6998poncho
Sep 25, 2015 02:56 PM
