Th350 New install advice!!
Old Jun 7, 2004 | 04:49 PM
stevver84Z's Avatar
Car: 1990 Iroc Hardtop
Hello, here's my setup:
350 ci motor, Holley stealthram, stock tpi stuff, stock long block
TH350 Street strip trans (built by probuilt) With Torco 9.5 inch 2300-2500 stall range
Steve Spohn crossmember/torque arm
rear is stock 2.73s!!
Here's the problem: i just got the trans installed and the car runnning. at lower rpm just cruising down the street the trans is fine. when i floor the motor the car feels like its really dragging almost like i'm riding the brakes. it takes a while for the rpms to reach max, the transmission downshifts fine and upshifts fine...
i talked to ProBuilt and it cant be anything with the transmission or else the tranny would be toast in a matter of miles, torque converter, maybe but from what i hear they are good torque converters... anyways he says it may be the rear gears...
is there anyone here who is running a similar setup with 2.73 gears???
can those gears really cause the car to drag that much???
dutch930
Sep 11, 2015 06:58 AM
Hello, Michael
Aug 20, 2015 03:19 PM
djmarch
Aug 19, 2015 12:07 PM
formula_novice
Aug 18, 2015 08:48 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
