HELP with VSS wiring
Old Jun 8, 2004 | 01:05 PM
WKDCAMARO's Avatar
Car: 1991 Camaro RS
Engine: 350TPI conversion
Hey guys, I have a 91 Camaro with a 89 Iroc Z 5.7 TPI in it. The 700R4 has the VSS module in it, but I need the plug and wiring and info on what pin outs the wires go to in the ECM from the VSS. Can anyone help? Does anyone have a plug they can sacrafice for me?
Old Jun 8, 2004 | 08:05 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Which computer do you have in it, the 89 or 91?
Old Jun 8, 2004 | 08:08 PM
WKDCAMARO's Avatar
Car: 1991 Camaro RS
They guy who I go tit from said the wiring harnes and ECM is also from the 89..
Old Jun 8, 2004 | 10:36 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If you are using the ECM from the 89 this could get interesting. The 89 ECM only has one pin for the VSS and that is pin "A10" and the 91 ECM has five pin locations. Pin "B9", "B10", "B11", "C1", and "D16". Actually pin "D16" on that ECM is for the Park/Neutral signal. These other pin locations mentioned are either not used on the 89 ECM or serve other purposes.
Old Jun 12, 2004 | 10:54 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello WKDCAMARO,
While working on another post with a similar problem I came across this information. To make the VSS work properly on your car you will need a VSS buffer box mounted near the ECM and wire in the following fashion according to this schematic. The yellow wire from the VSS on the tranny case will go to pin "D4" of the C100 connector and the purple wire will go to pin "E4". The signal wire from the buffer box will go to pin "A10" of the ECM through pin "K" of connector C207. Sorry about the info in my previous post.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
GTAman
Aug 27, 2015 10:29 PM
Bryan F
Aug 27, 2015 07:28 AM
fonzie85
Aug 13, 2015 11:50 AM
mizz0313
Aug 12, 2015 06:45 AM
