Another tranny problem.
Old Jun 8, 2004 | 10:54 PM
steve8586iroc's Avatar
Well it just seems strange to me that my transmission will shift and drive great for a while then it won't shift unless you put it in neutral and back into drive. Starting from a stop it will not shift out of first unless you either floor it and make the govenor shift it or as I said above, you put it in neutral, sometimes you have to do this more than once. I have changed the fluid and filter a couple of times to flush the old trans fluid out and checked the tv cable from the tb to the valve body. When I had the pan off the last time there was about a 1/4" of space between the tv cable cam and the tv plunger. Of coarse there is no fluid pressure on the plunger with the engine not running but I am curious if there should be a space there at all or if the fluid pressure would should take up the space when the engine is running. Thanks for any help and if anyone needs more info just let me know and I will get it.
Steve
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
HoosierinWA
Oct 7, 2015 10:15 AM
bjpotter
Oct 4, 2015 07:48 PM
