governor swap without dropping transmission?
Car: '93 S10 Short bed standard cab
Engine: 383 Stroker
Transmission: 92' stage 2 700r4 w/3600 stall
can I swap governors without lowering my transmission? I really need to do this, but I don't want to have to drop it.
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
Yeah, I just got done removing the governor in mine about a half dozen times getting the shift points right in my new tranny, no lowering/dropping of the tranny required. It's a little tricky to get the cover on/off without tearing it up with the cramped spaces though...
Engine: 383 Stroker
That's what I've got to do. 1st to 2nd is good, but the 2nd to 3rd shift is really quick. I've got 3 other governors that I can try though. So what is the best way to get that cover off?
Car: 94 Z28
Axle/Gears: 3.23s
Getting it off is fairly easy, I just removed the spring clip thing and then used a screwdriver tapped with a hammer to get under the lip and pry it off. Getting if back on I had to use a prybar stuck up through a hole in the crossmember and pry/slam the thing back on. Be careful you don't bend up the cover, could bind on the governor if it's bad enough...
ambainb
Apr 25, 2016 09:21 PM
