shifter
Old Jun 17, 2004 | 04:44 PM
brucefan's Avatar
Car: 85 Camaro Berlinetta
shifter
Looking for some help. The plastic piece that comes out of the shifter - can that be replaced. My broke where the plastic hole for the shift know hooks. Also if it can be replaced where would I get the plastic part. Thanks. The plastic rod inside the shift assembly is what I am asking about.
Thanks for any help
Old Jun 17, 2004 | 04:53 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Can you be a little more specific? Are you talking about the shifter plate, the shifter ****, the push button on the ****, or the plastic rod inside the shifter assembly?
Old Jun 17, 2004 | 05:27 PM
brucefan's Avatar
The plastic rod inside the shift assembly is what I am talking about.
Old Jun 17, 2004 | 06:46 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yes you can replace them, just go to a junkyard and pull the shifter **** off any 3rd gen or several other GM models with floor shifters and pull one out. Might cost a buck or two if that.
mcfastestZ28
Oct 5, 2015 07:12 AM
ndndndnd
Sep 28, 2015 08:00 AM
