Removing Axles...
Old Jun 19, 2004 | 02:07 PM
89IROCCVRT's Avatar
Car: '81 Camaro (Modded), '89 IROC cvrt (Stock), '00 GMC Jimmy
Engine: Modded 350 in '81, 305 TPI in '89 IROC, V6 Vortech in GMC
Transmission: T-350 in '81, 700-R4 in IROC
Removing Axles...
Right now, I'm trying to remove the axle in my 89 iroc convertible, and the c-clip wont come out. the rear end is even on an angle from the right to the left and it wont come out.....whats the easiest way to get the sucker out?
Old Jun 19, 2004 | 03:01 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Push the axle in. The C-clip will fall out.
Old Jun 19, 2004 | 05:16 PM
89IROCCVRT's Avatar
tried, even used our utility tractor and pushed the wheel and it didn't work
Old Jun 19, 2004 | 06:15 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Wheel?
You have to remove the wheel and the brake drum or rotor. No force is required; you should be able to just reach over with one arm and push the axle in, while cathcing the clip with your other hand.
Old Jun 19, 2004 | 07:28 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Of course you already took the cross shaft out, right?
Old Jun 20, 2004 | 12:41 AM
89IROCCVRT's Avatar
yeah the shaft was out, i've done it before on my 81 camaro and it just fell out....its ok though, i got it out....i wasn't thinking and the brake drum and wheel were still on (i rounded a lug ) so me and my dad used a cable puller and got it out
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
