Speedo don't work (speed sensor?)
Old Jun 20, 2004 | 05:09 PM
R.O.B.'s Avatar
My Speedometer quit working, how can I tell if its actually the speed sensor or not?
Old Jun 20, 2004 | 07:00 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Remove the speedometer cable at the transmission tailhousing, and see if it's good, you can attach a drill motor to the cable itself and spin it, and see if your speedo works. If it does, you have a speedometer gear problem inside the transmission. A common thing I see is the little clip that holds the plastic speedo gear in the trans coming off, which will cause the gear to move out of place and not work at all. hope that helps.
Old Jun 20, 2004 | 11:04 PM
R.O.B.'s Avatar
Thanks for the reply, but mine is electronic, not cable driven. And If I remove it and try your idea on the sensor shaft, I still wouldn't know if its a sensor failure or an electrical wiring problem.
Old Jun 23, 2004 | 11:48 PM
R.O.B.'s Avatar
Any suggestions?
Old Jun 28, 2004 | 05:54 PM
88gtatransam's Avatar
Car: 1988 Firebird Trans Am GTA
im haveing the same problem in my 88 TA... i replaced both the sensor and the gear and i still dont have a speedo.... i think its something with the wires... but i dont know
Jorlain
Aug 24, 2022 05:11 PM
9192camaro
16
Feb 3, 2019 12:21 AM
InfinityShade
Aug 22, 2015 08:00 PM
beachrodder
Aug 7, 2015 04:27 PM
