700R4 no gears
Old 06-21-2004, 08:23 PM
jamesbern's Avatar
700R4 no gears
I am pretty sure it is either the pump or the converter, because the thing has no line pressure and doesn't go into any gear. I just need an idea on how to check which it is when I drop the tranny. I have a spare of each and also a spare tranny, but I don't want to condemn parts that aren't bad or go back into this tranny for no reason. How do you check a converter. Also this thing popped extremely loud while in neutral being revved, then I lost everything.
Old 06-21-2004, 08:53 PM
jamesbern's Avatar
Found the problem, stupid mistake. I put a newer converter on an older tranny, different input shaft splines.
Hotrodboba400
12-10-2019 07:07 PM
db057
04-28-2019 07:45 AM
TheTraut88
09-07-2015 05:22 PM
UltRoadWarrior9
09-02-2015 08:24 PM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: 700R4 no gears
