Help Hooking up turbo 350 kickdown cable!!
Old Jun 22, 2004 | 01:49 PM
supermaxxbasher's Avatar
Car: 89 camaro RS
Engine: soon to be juiced built 357
Transmission: turbo 350
I have a holley 700cfm double pumper carb and a turbo 350 tranny and I have no idea how I am supposed to hook up the kickdown cable?? Is there an adapter I need to use so that I can hook it up? I know there is an adapter to connect a 700r4 TV cable to this carb but would it work for the kickdown on my turbo 350 as well??
Old Jun 23, 2004 | 12:36 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
FYI You don't need to hook up the kickdown cable if don't want, it won't hurt the tranny.
Old Jun 23, 2004 | 10:14 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
You should be able to go to any parts store that carries Holley items, Holley offers a package that comes with all different sorts of cable connections that will fit the holes in the throttle bracket of the carb-think I paid $12 or so for it, been a long time, just a matter of picking which one out of the assortment will hook up to the detent cable of the TH350. In the past when hooking this up, I found it easier to just get a universal detent cable from the tranny shops so I could adjust the length and actually get it to "kick down". This does involve removing the pan though, so try just hooking it up first before you dig in deeper than you may have too.
Old Jun 24, 2004 | 06:58 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What IHI said.... it's an extra little linkage piece that screws onto the carb. I don't think it's the same one as for a 700 but I could be wrong. There's a couple of different styles of cable ends for 350s, so make sure the linkage you get matches the cable you have.
Old Jun 24, 2004 | 08:49 AM
Car: 89 camaro RS
Alright I found some parts that SHOULD work...here is the turbo 350 kickdown cable manifold bracket http://www.holley.com/HiOctn/ProdLin...SCA/20-45.html and then here is the stud that the cable SHOULD mount to http://www.holley.com/HiOctn/ProdLin...SCA/20-40.html
Frozer!!!
Jan 19, 2024 04:55 PM
camaro71633
Sep 1, 2015 10:24 AM
Eric-86sc
Aug 24, 2015 09:01 PM
Accerrito22
Aug 23, 2015 07:22 PM
crazynights
Aug 21, 2015 06:53 AM
