How do you clean a used posi & gears?
Old Jun 26, 2004 | 06:36 PM
yzarcem's Avatar
Car: 82 Camaro; in process of resto
Engine: 350 4bbl.
Transmission: 700R4 with B&M Lockup
Axle/Gears: Moser 28-spline axle; 3.23 gears
I just bought a used torsen posi with gears from a 99 Camaro SS with 66k miles. How can I clean & lube this up for a 'like new' installation?
Old Jun 26, 2004 | 07:52 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Diesel fuel, followed by lacquer thinner; no lube is really necessary, just fill the case up with fluid. Maybe put a little white lithium or something in the new bearings you put on the pinion and carrier.
Old Jun 28, 2004 | 02:49 PM
yzarcem's Avatar
Engine: 350 4bbl.
Thanks! I will do that.
Last question--It will sit on the shelf for 3 or 4 months before I install it (converting 26 to 28 spline)...should I let the posi sit in fluid for storage, or just let it sit in the open?
Old Jun 29, 2004 | 05:55 PM
Red Berlinetta's Avatar
Car: 1985 Berlinetta
Engine: 305 LG4 (stock)
Transmission: 700-R4
Hose it down with WD-40 and put it in a plastic bag.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
