4th gen rear & clearence
Old Jul 1, 2004 | 10:49 AM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Ok, I've done the searches. I know that the the 4th gen axles petrude out 1 1/2in on each side and that you need a proportioning valve to swap it and that all third gen surrounding parts bolt up. But here is my question. From the looks of 4th gen rears on other cars, the tires look even with the 1/4 panel lip. If you hit a bump, will it touch? I don't know if I'm saying this right but it looks like the tire could mess up the 1/4 panel. Any input would be greatly appreciated.
Old Jul 1, 2004 | 10:57 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It reall depends on what wheel you use. You can run a 4th gen rear and with the proper back spacing keep the tire tucked under the quater panel. Your bump stop should prevent any damage to the quarter panal if you are running really tall tires that run flush with the outside.
1992rs/ss
Jan 31, 2025 05:10 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
