Rachet Shifter
Car: 1991 Camaro RS
Engine: Stock 305 TBI
Transmission: Stock
Rachet Shifter
Noob Alert, hope someone can help me out anyway.
Alot of people put rachet shifters, such as the B&M Megashifter on their automatics. The advantage being they can rachet the gears. I'm a little confused as to what this means. Do they mean you can select what gear you are in, from 1st to 4th, just like a manual lets you select a gear? Could you really select your own gears with a automatic?
That seems worthwhile if thats how it works. If i'm wrong (probably), can someone explain the concept for me?
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
All the Ratchet shifters do is allow you to shift manually from first through 4th without accidentally shifting more than one gear at a time. You can't start out in 2nd gear for instance. The trans will always start in 1st. It also allows you to ratchet down a gear in the same manner.
Hope that helps somewhat.
Car: 1991 Camaro RS
Transmission: Stock
So, for example, when you put it in the rachet position, you could stay in first as long as you want, until you shift it, correct?
Edit: Does anyone make a console shifter that fits our cars besides the B/M one?
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
The B&M MegaShifter also allows you to down shift in a similar manner.
I think Hurst may also make an F-body console model.
