rear swap
Old Jul 10, 2004 | 12:23 PM
nwardoh's Avatar
rear swap
My wife and I are working on building up her camaro... This will be a strictly street car. The plans for the car include a 383 stroker with the 700r4 trans(rebuilt)... We want to put a posi rear in it but need some advice... I am not wanting to spend 2000-2500 for just the rear end. A local guy told me that there were some of the s-10s and blazers that had the correct length rears with the correct mounting hardware. They would have been 4cyl trucks with gear ratios around 3.73. Does this sound right? I would go through it and clean it up, replace the seals and such... Are there any other stock rears that will be a direct bolt in? The car will have the stock 305tbi in it until we get the motor in(prolly this winter)... Is there anything else that I would need to do right away to make the new rear work?
How about rear disk conversion for this car? anything off a factory car that will work? What would I need to do the install?
thanks
Dustin
Old Jul 10, 2004 | 01:27 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Yes the new camaro rears will bolt right in. The small truck rears are the same but i don't think they have coil springs or torque arm, so don't do that. You could grab the gears and posi form one though.
Old Jul 11, 2004 | 11:27 AM
blackgold84's Avatar
Car: 1984 Z/28 Camaro
Engine: 350ci
Axle/Gears: 9" 3.73 spool
chack this out, ill be doing many of these upgrade when i change my gears and add my posi unit...
look here for rear upgrades
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
E Rod
Aug 28, 2015 05:17 AM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
