Install 700R4 and NOT set line pressure??
Old Jul 12, 2004 | 02:53 AM
CrazyHawaiian's Avatar
Car: too many ...
Just curious if anyone here has installed a 700R4 and NOT set the line pressure (just adjust TV cable properly) and then had the transmission last? I've dropped the 700R4 out of my 89 RS and plan to keep it on the side for a later project. I'm wondering if I can swap it in at a later time and not have to deal with setting line pressure. As long as you dont mess with the tab then the factory settings should hold right? So the only thing left is to adjust the TV cable properly? Sorry if this is a stupid question, but I've heard so many horror stories about the 700R4 burning up because of improper line pressure, I had to ask.
Old Jul 12, 2004 | 03:31 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
I removed a 700-R4 (1990 core; rebuilt ~20k ago) from a car, made sure not to move the slider, and reinstalled it without ever moving the slider. The settings were perfect; I tried changing them a few teeth each way, 1 or 2 teeth at a time, and the "original" setting was best. The cable and the optimal TV setting will not change in storage, which I hope answers your question.
Old Jul 12, 2004 | 03:46 AM
Duck's Avatar
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
Re: Install 700R4 and NOT set line pressure??
I was always under the impression that adjusting the TV cable changes the line pressure, that there are not an additional line pressure adjustments without going inside the trans.
Old Jul 12, 2004 | 07:46 AM
Car: too many ...
Yeah you are right, I worded it wrong. I know I'll probably have to set the WOT setting on the TV cable every time the transmission is swapped, but then isnt there also that second part about setting line pressure that deals with the different RPM's (1,000rpm, 2,000rpm, 3,000rpm etc) and matching it up with the line pressure (using a pressure guage?). I've seen a picture on these forums showing how to set the line pressure correctly and it had a chart with all the different RPM's and what the line pressure should be at each RPM interval. Thats the part I dont really want to deal with. I'm hoping I can just swap the transmission back in later, set the WOT position on the TV cable, and then be done with it. Sorry about that (I write like a wetard sometimes hehe). But hey, jmd is giving me hope! I'll make sure not to mess with the slider. Thanks man!!
Old Jul 12, 2004 | 11:40 AM
jmd's Avatar
jmd
If I'm understanding you correctly, the pressure test you describe is just the "put a gauge on the pressure port and check the trans. for proper pressure" test... that's something you really only need to do when troubleshooting a trans. It's certainly not a bad thing to do to check the health of the trans., but I don't ever check it on a trans. that works fine. If you run across that pic...
Old Jul 12, 2004 | 02:01 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Yeah, you check it to make sure it is right with a pressure gauge (awesome tool to have, btw). There is no specific adjustments if something doesn't agree, it just lets you know there is a problem somewhere...
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
wayshegoes
Aug 17, 2015 12:00 PM
Kaweh
Aug 9, 2015 02:54 PM
drathaar907
Aug 6, 2015 04:20 PM
