t5 swap problems, please help
Old Jul 12, 2004 | 03:34 PM
parkerbender's Avatar
Car: 92 RS
Engine: 305 tbi (lo3)
Transmission: t56
I am swapping a '85 warner t5 into my 92 rs, i have 2 problems, whell, i have a lot of problems but two pressing ones, first, where can anyone find a v8 belhousing, and second, is the six banger t5 weaker than the v8 version? i've heard diferent stories from everyone i talk to so I was wondering if anyone actually knows or has a six banger tranny behind their v8 I have the factory roller 305 which is also gonna get a cam and 144 powercharger, so it would probably be good to know if the tranny will blow up with 350 horses going through it, thanks,
the friendly frm kid engineer, -parker
p.s., oh yeah, the reason i'm going with a 6banger tranny is the lower 1st gear and that i found a donor car for 200 clams, just thought the first ten replies would be: wtf are you doing that for?
Old Jul 12, 2004 | 03:54 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: t5 swap problems, please help
Originally posted by parkerbender
'85 t5 into 92 rs
  • where v8 belhousing
  • six banger t5 weaker than the v8 version?
  • reason i'm going with a 6banger tranny is the lower 1st gear and that i found a donor car for 200 clams
  • Third Gen classifieds are good. eBay ain't bad. Local junkyards; many have a "parts finder system" to work with other junkyards if they don't have a part.
  • Yes. Any "lower" first gear (numerically higher) makes for a weaker transmission. The closer you get to a 1:1 ratio, the stronger the gearset is.
  • You can always swap to a V8 trans. later, but the clutch disk has to be changed and pressure plate / flywheel surfaced at that time.
Old Jul 12, 2004 | 07:36 PM
Car: 92 RS
Transmission: t56
durability
do you think that with the ~3.43 1st gear it would lower the durability enough that you would be leery to put it into a lo3 with a 144 powercharger probably making 350-400hp? are they physically less durable or is it just theat since the ratio is .5 lower it'll be about 1/7 less duralbe than the normal v8 ratio of about 3:1 in 1st? any other opinions?
Old Jul 13, 2004 | 01:32 AM
jmd's Avatar
jmd
Re: durability
Heck yes I'd be leary. Point blank: You're gonna spend the $ now (on a T56 for example) or you're gonna spend it later when the T5 breaks. You're on a budget, so I understand where you're coming from, but I'd rather spend $ on a T56 than on a blower but that's me.
The input shaft is lower spline, thus weaker, and the gearset being lower ratios is going to be weaker.
Old Jul 13, 2004 | 01:54 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
hahahaha GM wouldnt put the V8 T-5 Behind the 350's because they thought the 245 hp 345 tq would be too easy to blow them up. You want to put a v6 5 speed behind 350-400 hp. Have fun with that id be happy if it made it to the end of the driveway!
customblackbird
Aug 15, 2021 10:16 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
nuggie
Aug 25, 2015 01:27 PM
theurge
Aug 21, 2015 12:46 PM
sreZ28
Aug 14, 2015 07:48 PM
