700R shifts from into second while in manual low
Old Jul 14, 2004 | 02:00 PM
coprunr's Avatar
Car: 89 S10 Blazer
Engine: 4.3
i have a 84 Z28 with a recently rebuilt 700R from a 86 Suburban with a TCI shift improver....if you put it in manual low it will shift into secong while in manual low , and will not down shift into 1st from second at speeds over 10 mph......wondering if it is part of the shift improver or normal for a 700R...it shifts into second at about 4200 rpm while in manual low.....and if your are in OD and @ WOT from a stop it will shift at roughly 2800-3200 rpm ....the engine is a strong 406 that makes peak power at 5200 rpm...it is killing the acceleration shifting so soon
Old Jul 14, 2004 | 02:29 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I suppose some would blame TCI for not fixing what the factory did "wrong", but sounds like it's doing normal factory things.
Except you might want to check the TV cable adjustment. Sounds like it's shifting unusually low @ WOT in OD.
Old Jul 14, 2004 | 10:32 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
You'll probably end up needing a new governor for that if its from an 86 suburban. However, I'll second the fact that it should be shifting later then that even with the governor it has.. I'd verify proper TV cable adjustment too. Also, keep in mind that the TV spring that actuates the valve in the valve body might be worn too (making it hard to achieve the "proper" adjustment)..
Old Jul 15, 2004 | 11:17 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
To get a 700R4 to hold first gear install the TransGo reprogramming kit. With this kit there is a new valve and some holes drilled that allow first gear to be held to any RPM.
RBob.
Old Jul 15, 2004 | 11:26 AM
coprunr's Avatar
Car: 89 S10 Blazer
Engine: 4.3
the first thing i did was check the TV cable....it is perfect...the tranny will hold second till you shift out of manual second , it will not shift from second no matter what the rpm.......is that normal as well? only shifting out of 1st ?
Old Jul 15, 2004 | 04:07 PM
Pro Built Automatics's Avatar
Yes. Only the Trans-Go will give you the ability to "hold" manual low. The TV cable should be tight at WOT. If it still shifts at a low rpm at WOT then the TV system is not setup correctly, the Trans-Go Perfromance Shift kit should solve this. You could try a lighter weight governor, if the shifts are firm at WOT (even at the low rpm) that is occuring now.
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
g.l.mos
Aug 22, 2015 12:02 AM
mizz0313
Aug 12, 2015 06:45 AM
dhonda200
Aug 11, 2015 11:50 PM
