corvette servo instal problems.
Old Jul 16, 2004 | 07:27 AM
89305RS's Avatar
Car: 96 s-10, and 89 camaro RS
Engine: 305 TBI with alot of mods
Transmission: 700R4 B&M shift kit
we cant get the retaining ring off of the servo cover AND the servo cove will no move. I was just wondering if anybody has experianced this problem or any ideas would just be awesome.
Old Jul 16, 2004 | 08:27 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: corvette servo instal problems.
Yes, they can be troublesome.
Until the cover moves the retaining ring won't come off. The cover needs to be pushed in a little to get the ring off.
Put some PB blaster or Kroil around the edges of the cover and let it soak a bit. I found that using a small hammer and tapping (!) on the center of the cover will help free it up (only tapping!).
IIRC there is a hole or two around the outside of the housing. Placing a punch through the hole and it can be used to push the ring toward the inside. Then get a screwdriver under it.
The slot in the housing is there to allow the seal to be hooked, pulled out some and cut. Then pull the seal out entirely (sela is an O-ring).
RBob.
Old Jul 16, 2004 | 12:14 PM
89305RS's Avatar
well we got the ring out but now the cover wont pop out. Any ideas for that. When i put my servo in all of these problems didnt exist.
Old Jul 17, 2004 | 09:18 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Make sure the O-ring has been pulled out first. IIRC I then used the pry bar against the cover (up into tunnel w/block of wood protecting the sheetmetal) and kept pushing the cover in and allowing the spring to puch it back out. Eventually it started to come out.
Some have also grabbed the cover protrusion with pliers to help wiggle it out. Just don't destroy that area as the servo pin sits inside of that part.
RBob.
Old Jul 19, 2004 | 02:32 PM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
Axle/Gears: Moser 4.56
Keep wiggling that thing back and forth,, it will eventually come out. Your green seal is doing it's job quite well, by not letting you just pull it out. But, it will eventually come out. You can do it......
Old Jul 19, 2004 | 03:58 PM
Pro Built Automatics's Avatar
You have to cut the o-ring, then pull the o-ring out, now the cover will come out.
Frozer!!!
Jan 19, 2024 04:55 PM
toronto formula
Nov 10, 2015 06:17 AM
dhonda200
Aug 11, 2015 11:50 PM
drathaar907
Aug 6, 2015 04:20 PM
