trans swap problem
Old Jul 19, 2004 | 12:36 AM
bad ass 85 ta's Avatar
trans swap problem
I recently swapped my r4 for a t5. my r4 has a mechanical speedo, and my t5 has an electronic. this is a problem since my speedo now can't function. does anybody know if all t5 transmissions are elect. speedo? if they are not, would you have any idea where to find a mechanical drive?
Old Jul 19, 2004 | 01:54 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Email me your tyre size, differential rear gear ratio, the colour of the gear inside the transmission, and I'll get ya hooked up with the right parts.
Old Jul 19, 2004 | 09:48 PM
I sent you an Email but I don't if you recieved it. I'm kinda new at this computer stuff. if you didn't let me know and I'll try this again. Thanks for your help.
Old Jul 20, 2004 | 06:37 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes the T-5 came with a cable seepdo as well as electric. They interchange directly.
All you need is the speedo gear sleeve, and the right speedo gears for your rear end and tire size.
Here's a T-5 VSS and cable sleeve side by side, just to show you how trivial the swap is. One bolt.
Attached Thumbnails trans swap problem-t-5-speedo-gear
Old Jul 20, 2004 | 06:43 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Here's a T-5 speedo gear, and a new replacement sleeve from the dealer. This sleeve is steel, compared to the chinesium OE one. Much better quality than the OE sleeve in the first pic. The gear just slides into the sleeve.
As you can see, this is like a 2 minute job, if the car is already jacked up.
Old Jul 20, 2004 | 11:17 AM
so i could pick one up from a gm dealer?
Jorlain
Aug 24, 2022 05:11 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
hokis
Aug 9, 2015 03:57 PM
