tranny troubles
Old Jul 20, 2004 | 11:49 AM
SickSleeper's Avatar
Car: '90 RS
Engine: 350 bored .30 over
Transmission: blown 700r4
tranny troubles
ok recently swapped out the lil 305 for a carb 350 and i used to original th700 tranny that was with the 305. my friend put the tranny on the motor and i was working on some wiring so i really wasnt paying attention to what he was doing. now the tranny wont even go into gear. i thought at first it could have been airlocked so i reved it up in gear and everything and still nothing. it does have the proper amount of fluid in it, could it be that he put the torque converter in wrong or somthing? im totally stumped on this, would tv cable being off have any effect like this? im open to any suggestions u guys might have, but i really hate to pull the tranny again seeing as how i jus got it in there, but ill do what it takes, lemme know what u all think bout my problem thanks, jon
Old Jul 20, 2004 | 09:53 PM
bad ass 85 ta's Avatar
I have an r4 in my 4x4, and forgot the tv cable. It still went in gear, it just did not shift. If the converter was not seated in the pump the whole way when he tightened the conv. bolts, firing the motor could have broke the ears off of the punp. If this is the case, the pump won't turn and you won't have any gears.
Old Jul 20, 2004 | 10:06 PM
ljnowell's Avatar
I dont think that your friend hooked the torgue converter back up to the flexplate. Double check this, because that is exactly what it sounds like.
Old Jul 21, 2004 | 12:38 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Was the converter filled before it was installed?
Old Jul 22, 2004 | 12:13 AM
Car: '90 RS
no my friend jus informed me that he didnt put any fluid into the TC and from what it sounds like he didnt seat it correctly either so there lies my problem looks like its coming back out tomarrow, thanks guys - jon
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
mrbird
Oct 20, 2015 03:43 AM
bjpotter
Oct 4, 2015 07:48 PM
Lmancha96
Sep 25, 2015 08:11 PM
IROCZ1989
Sep 4, 2015 11:54 AM
