HELP 9 bolt question!!!
Old Jul 21, 2004 | 02:54 PM
2out_The_Left's Avatar
so i need a new seal and bearing for the left side of my 9 bolt. i took it from an 85 TA and popped it into my 86 camaro (drum to disc swap) so i call up autozone and they ask me :is is a 7.25 ring bearing?" i asked the GM dealer the same thing and got the same question. well my answer was "hell if i know". so my question to you all is it a 7.25 ring bearing? i know theresa bunch of different sizes in the 10 bolt but i didn't know about the 9's. please help so i can stop this diff leak in my driveway
Old Jul 21, 2004 | 03:13 PM
ede's Avatar
ede
not sure what they're asking you or what you think they're asking but there isn't any thing close to a 7" bearing in any rear end for a car, even a top fuel dragster. why not take your old bearing and seal with you and match it up with the replacement.
Old Jul 21, 2004 | 04:12 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
I think they want to know if its a 7.65 or 7.75 ring gear rearend, the 9 bolt has a 7.75 ring gear just make sure its for disk brakes when you order the part.
Old Jul 21, 2004 | 06:32 PM
yeah i knew the guy sounded off with the questions. i cannot believe they don't have it by disc or drum in those computers they use. i'll prob end up taking the old stuff down there and matching it up. can't leave it off long though, don't want the insides exposed.
Old Jul 21, 2004 | 08:23 PM
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
I remember the bearings are called a 'set 9' or something similar to that terminology. Also, the seals are different from side to side (I don't remember those part numbers.) When I asked for them at autozone one seal was $2 and the other was like $9 or something. They didn't ask about my brakes any and I don't have any leaks.
84z96L31vortec
Aug 20, 2017 12:16 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
