TPI TV cable...700-R4 vs. 200-R4?
Old Jul 23, 2004 | 12:01 AM
quadgoat's Avatar
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
Hey guys...I'm wondering if there are any differences between the TV cables used on the 700-R4 and the 200-R4. The reason I'm asking this is because my friend just swapped an '88 TPI 305 from a Camaro into his El Camino and is running a 200-R4 behind it. Since he needed a longer TV cable to work with the TPI setup he just got a 700-R4 TPI cable and hooked it up. It works great until the engine warms up and goes into closed loop (I don't think that should affect how the tranny shifts since the only electrically controlled part of the tranny is the torque converter lockup), then it starts shifting funny. The engine also starts having a bit of a flat spot when you open it up, but I think that's another issue. Anyway, if anyone knows if there are any differences between TV setups for the 700 and 200 trannys I'd appreciate your input! Thanks so much!
-Paul
Old Jul 23, 2004 | 12:02 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I believe both should use the same TV cable.
Old Jul 23, 2004 | 10:09 AM
quadgoat's Avatar
Car: 1992 Firebird
Thanks Apeiron, that's pretty much what we thought too, so this issue must be something other than a TV cable issue I guess...
Old Jul 23, 2004 | 12:14 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Engine problems can appear like strange shifting problems sometimes, for example a flat spot can make shifts feel late and hard.
Old Jul 23, 2004 | 07:16 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
The 700 & 200 use the same travel for TV.
unplug the 4 pin connector at the trans. If that doesn't change anything, it's not electrically transmission related. Since you say it changes in closed loop, I'd also say it's not TV cable related.
Hopefully he didn't gimp it up with a Painless or otherwise craptastic efi harness.
Old Jul 23, 2004 | 10:17 PM
quadgoat's Avatar
Car: 1992 Firebird
Yeah....I'm pretty convinced it's not actually transmission related...but I'll tell him to try unplugging the torque converter lockup connector and see if it makes any difference.
I certainly got a chuckle out of your wiring harness comment jmd...why do you dislike the painless harnesses? That is what he's using. It all seemed to hook up very well and seemed to be fairly decent quality. It's a stock '88 TPI setup with the stock computer and a painless harness.....is there anything in particular you think we should check on the harness, or have you just had bad luck with them in the past?
Old Jul 25, 2004 | 03:57 PM
MonteCarSlow's Avatar
Car: 1988 Monte Carlo SS
Engine: 5.7L TPI
...just a reply from someone that's run a TPI 700 TV cable on a 200-R4. It works just fine.
EdB
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
