snap ring in T5
Car: 86 Monte Carlo SS
Engine: Vortec 355, xe268 cam
Transmission: WC T5
snap ring in T5
I am in the process of replacing the speedo gear inside my T5. I bent the snap ring outward too far when removing it (cause i didn't use the right tool - doh). Its like the one in the pic in this post https://www.thirdgen.org/techbb2/sho...ight=snap+ring only I mine it is to the outside of the speedo gear (left side in that pic) just past that rubber oring thingy.
Do I have to order this from a dealer or could I find it at a parts store?
Also, every pic I have seen of the T5 doesn't have this snap ring where mine was. Is it supposed to be there or no?
Car: 4
Engine: 6
Transmission: 5
It's supposed to be there.
You can maybe get one at the dealer, or maybe at the junkyard, or maybe even at a shop that works on manual transmissions. I probably have a dozen or more of them laying around from T-5s and other transmissions I've worked on, that I accidentally didn't throw away. There's several of the same ring in the trans, and they come in a rebuild kit; so they kind of tend to accumulate.
Car: `86 SS / `87 SS
Re: snap ring in T5
LT1Formula
Oct 8, 2015 08:34 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
