Which ATF fluid? Dexron II or III for Th-700-R4?
Old Aug 1, 2004 | 07:40 PM
Dr G's Avatar
Guys,
Should I use Dexron 2 or Dexron 3 automatic transmission fluid. The Haynes manual says Dexron 2 ATF. The car is a 1898 GTA with Th-700-R4 auto trans.
A search for posts with Dexron in the title yeilded these results:-
HELP!!!!I did a no-no atleast i think i did with my trans..Put Dexron V and not III
https://www.thirdgen.org/techbb2/sho...ghlight=dexron
Differences between dexron II and III
Hurst trick shift dexron II
From them. it seems that it should make little or no difference. Anyone agree/diasagree?
Old Aug 1, 2004 | 07:52 PM
Dr G's Avatar
Two other threads:-
GM Dextron III ATF ???
https://www.thirdgen.org/techbb2/sho...n+fluid+dexron
Which Tranny Fluid To Use For Firmer Shifts???
I guess I seem to have just answered my own question!
Dr G's Avatar
Sorry double post for some reason.
Old Aug 1, 2004 | 07:58 PM
MdFormula350's Avatar
II is what is called for back in the day, but III is fine for it.
Old Aug 1, 2004 | 09:31 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yup, the II has been supplanted by the III. Anything the II will do, the III will do the same or better.
Kind of like your motor oil.... your oil cap might say something like "use SG only", but you go to the store and all they have is SH.... the new standard.... do you just not change your oil? I don't think so.
Old Aug 2, 2004 | 03:23 PM
Dr G's Avatar
Thanks RB83L69 and MdFormula350. I'll be changing it along with a fresh filter tomorrow!
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
mfp189
Sep 27, 2015 09:25 AM
HikoriYami
Sep 21, 2015 07:11 PM
