How much room in the trans pan for sender?
I bought myself a few gauges, Fuel pressure (dakota digital), Trans Temp (dakota digital, and a voltmeter.
Anyway I have hooked everything up except the trans sender.
Does anyone know how much room there is inside the trans pan if I mount it on the side of the pan? The sender is pretty small about 2" long max.
About 1" of it will be inside the pan. Now I am not sure how much room there is inside the pan so that when I get a nut welded on and screw in the sender that it will not foul on the trans inside.
Does anyone know how much room there is around the pan inside?
I figured this would be the best spot to mount the sender as this would give the most accurate temperature what the trans is running at.
I have read some people not recommend drilling a hole in the pan but I am a firm believer in doing things right and frankly I don't see any other better way of doing it.
maroe624
Apr 16, 2017 08:29 AM
ambainb
Apr 25, 2016 09:21 PM
NBrehm
Aug 25, 2015 11:49 PM
