Stall on a Torque Converter
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
I was wondering. What exactly does the stall mean on a torque converter. I am going to be swapping out my L03 in the near future with a 350 High Output engine which will be hitting 350hp/425lbs torque at the flywheel (*** knows what at the rear wheels). Should I replace the stock torque converter with an upgraded one. TCI, Vigilante, B&M...those are a few names I know from magazines...do you recomend any of these and if so what stall should I pick?
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Stalls have been talked about alot recently. Just look down the threads and you find them.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
