No OD or reverse. 1st shifts at 3600rpm
Old Aug 8, 2004 | 08:58 AM
JWKbride's Avatar
Car: 1992 Pontiac Trans Am Convertible
Engine: 305 H.O.
Last night I was getting on the interstate at full throttle and at 70 mph when it shifted from 3rd to OD I heard a pop and intermitant grinding sounds.
I stopped and checked the fluid, still red no leaks
1st- wont shift till 3600 rpm
2nd -seems when it goes from 1st it goes directly to 3rd.
3rd- normal
OD- will not go into OD
No griding sounds etc.
Any ideas?
John
Old Aug 8, 2004 | 05:47 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Problem with the band or sun gear shell. I've replaced several broken sungear shells for this same problem!
Old Aug 15, 2004 | 09:16 AM
JWKbride's Avatar
Engine: 305 H.O.
Well I had this transmission rebuilt and while they were at it had them add a 2000 stall from a same year corvette. Runs great, shifts on redline when in OD when I have the car floored.
Hated to spend the $1,200 but the car is much smoother now and is a better driver.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
