is this a bad thing?
Old Aug 10, 2004 | 07:58 PM
jake_91_rs's Avatar
Car: 1991 RS Camaro
Transmission: 5sp
ok is it a bad thing when you know your car so well that you can remove the driveshaft and drop the crossmember , drain the tranny fluid and replace the plug in the back of the shifter housing and put it back together in less than an hour? I think its kinda bad when i know my car so well
Old Aug 10, 2004 | 08:03 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Trying to think what you do with the other 45 minutes...
91rsv6's Avatar
Car: 87 IROC Z
Engine: 5.0 TPI
Why have you done it alot?
How for are you from st.louis.
Old Aug 10, 2004 | 08:05 PM
jake_91_rs's Avatar
Car: 1991 RS Camaro
Transmission: 5sp
well i took the tranny out and rebuilt it and put it back in so i've only been over the nuts and bolts 2 times but still........
well i'm 2 hrs north of columbia
Old Aug 10, 2004 | 09:54 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
sometimes it amazes me just how well I know my car. Its cool to be able to do those kinds of things with such proficiency.
Old Aug 11, 2004 | 05:14 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
The best I have it down to is from pulling up into the driveway to having the t56 sitting next to the car right around 45 minutes.
xxx3man`
Sep 23, 2015 10:37 PM
Jae992
Aug 27, 2015 09:07 AM
Bob88GTA
Aug 18, 2015 03:31 PM
