How to remove speedo gear -700r4
Old Aug 14, 2004 | 08:37 PM
CEP89's Avatar
Car: 89' IROCZ
Engine: 5.7 L98
I'm changing speedo gears because I changed my rear axel ratio. I have the tailshaft housing off, but I can't the clip off that holds the gear on. It looks like a strip of metal that has one end rolled into an eye and the other end has a 90* bend. What's the trick to getting it off?
Old Aug 14, 2004 | 08:47 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You squeeze it toward the shaft. It has a tab that goe in a hole in the shaft to hold it to the shaft, and 2 smaller tabs that grasp the sides of the gear. Push the outer half toward the shaft and slide the gear off over it.
Old Aug 15, 2004 | 07:43 PM
CEP89's Avatar
Car: 89' IROCZ
Engine: 5.7 L98
Thanks for the tip. It worked great.
Jorlain
Aug 24, 2022 05:11 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
3rdgenparts
Aug 8, 2015 07:09 PM
beachrodder
Aug 7, 2015 04:27 PM
