TCC won't lock on freeway
Old Aug 15, 2004 | 10:51 PM
GoonieZ28's Avatar
Car: 91 Z28
Engine: 5.7 TPI
Transmission: ProBuilt 700-R4 & Vigilante Torque Converter
My TCC doesn't lock while I'm cruising on the freeway. It used to do this before. It locks and unlocks just fine on the streets (around 40-50 mph). This seemed to start after I gave my car a tune up. Is there a specific sensor that tells the computer to lock the TCC once your at a constant speed on the freeway (like 70)? Is there something else? Any help you can provide would be great. My break pedal does unlock my TCC on the streets...
Thanks!!
Old Aug 16, 2004 | 11:42 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
The tps is the other main sensor used along with the map. Since its locking at 40 you can pretty much rule out the vss and the 4th gear switch.
Old Aug 16, 2004 | 12:09 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
What temperature does it run at on the freeway?
TX-SleeperC5
Feb 24, 2016 01:34 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
camarohelp
Sep 22, 2015 03:19 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
scottmoyer
Sep 7, 2015 07:06 PM
