swapping 7.625 gears, need specs thanks
Old Aug 16, 2004 | 08:24 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
ive got an 87 s-10 3.42 7.625 axle out here and i have crappy highway ratio in the axle under the 82 trans am, its way too high of ratio, 3.42 would be perfect in the car,
so other than a new crush sleeve what else would i need in order to set up the s-10 carrier and gears into the trans am rear ?
how much backlash is good for a used R and P ?
set used gears tooth contact pattern more towards heel or toe ?
thanks
Old Aug 16, 2004 | 08:27 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
For teh S-10 carrier, you need some other carrier, unless you just like working on that rear.
You need bearings and a shim kit, and a handful of tools.
For a used R&P, I'd suggest .006" - .009".... basically, to the low side of the tolerance range. But not below .005". Gears (or any other piece of metal) "grow" when they get hot, and the backlash goes away; better to have a little too much, than end up in a situation with "negative backlash". I have learned from hard experience, that 2 metal parts can't occupy the same volume at the same time.
Old Aug 16, 2004 | 08:42 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
lol so true hehe
metals dont like it when another invades its space! :P
im totally lost on what you mean there
just not seeing it, its not clicking in my brain right now,
you mean that the s-10 carrier wont work in the t/a housing ?
or ?
arent 82 trans am axles 7.625 ?
no ?
they actually 7.5" ?
thanks
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
InfinityShade
Aug 22, 2015 08:00 PM
theurge
Aug 21, 2015 12:46 PM
mizz0313
Aug 12, 2015 06:45 AM
