Need speedo help after new motor install
Old Aug 19, 2004 | 09:46 AM
9D1BURD's Avatar
Moderator/TGO Supporter
Car: 1997 Z28
Here is my problem, i have a 91 firebird that was originally equipped with a 3.1 liter, auto 3:23 rear.
I took a 1987 305 tpi and auto trans and put it in my 91.
I kept my stock 3:23 rear end.
So basically its a 91 with an 87 motor and trans. The 87 had a 2:77 or 2:73 rear.
The trouble i am having is getting my speedo to be correct. Is that becuase of the 87 vss?
Do i need to change speedo gears or anything? I assume vss and rear end ratios are related. Do i just need a vss set for a 3:23 rear?
Any help would be great, thanks
Old Aug 19, 2004 | 11:53 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You will need to get the correct speedo gears for your rear end and tire height.
Old Aug 19, 2004 | 11:59 AM
9D1BURD's Avatar
Car: 1997 Z28
I guess i am confused on why my speedo gears need to be changed. The speedo is from the 91, so is the rear. Sp the speedo sees a 3:23 rear, which is what it has.
Old Aug 19, 2004 | 12:07 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
All speedos are the same, they don't "see" any rear gears. They all want to see the same number of turns/mile of the cable, or pulses/mile of the VSS. The ratio of the speedometer gear converts turns of the rear wheels into the correct number of turns per mile.
If you didn't change out the gears in the transmission before you put it in, then you have speedo gears for a 2.73 rear. Change them.
Old Aug 19, 2004 | 12:53 PM
9D1BURD's Avatar
Car: 1997 Z28
Ah, now i see, thanks for your help
1992rs/ss
Jan 31, 2025 05:10 PM
Jorlain
Aug 24, 2022 05:11 PM
evilstuie
Jan 9, 2020 08:29 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
beachrodder
Aug 7, 2015 04:27 PM
