Odd trans question
Old Aug 19, 2004 | 04:23 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Odd trans question
I was going down the road in Formula, shifted into neutral and reved to 3500. The car jumped forward a bit, like the clutches were engaging??
It isnt a problem since this isnt a typical thing for me to do, but its got me wondering what the heck causes it to do that
Old Aug 19, 2004 | 05:12 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Centrifugal apply?
Old Aug 19, 2004 | 05:18 PM
Guest
Guest
Posts: n/a
Re: Odd trans question
what do you mean by it jumps forward a little....
Old Aug 19, 2004 | 05:32 PM
SweetS10v8's Avatar
Engine: L98 & 355ci
I put it in neutral and coasted a bit, when I hit the gas the car started to pull like it was in gear for a fraction of a second.
I dont know how to say it better than it just jumped forward a bit like it was in gear
Old Aug 19, 2004 | 05:39 PM
Guest
Guest
Posts: n/a
Originally posted by Apeiron
Centrifugal apply?
i think he is right it happens its normal nothign to worry about
Old Aug 21, 2004 | 09:32 PM
chris718's Avatar
it usually is a sign that there is not enough clearance in the forward clutch pack allowing the clutch pack to drive the sun gear and initiate a driving force into the planetary gearset.it could also be a hydraulic crossleak or that the apply oil behind the clutch piston doesnt exhaust fast enough.does it pull forward in park or nuetral when stopped if you rev it up?it could also be the forward clutches are burnt causing them to drive the sun gear as they are trapped onto the input sprag.
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
Leggman1
Aug 6, 2015 04:15 AM
