Rear End upgrade
Old Aug 20, 2004 | 06:52 PM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
Rear End upgrade
Well, a buddy of mine has an old 1986 Camaro that is being parted out. He is selling me the rear out of it. The rear is a posi rear with 3.73. My current setup is a Pegleg with 2.73.
Is this new rear end gonna make a big impact on my cars drivablility?
Old Aug 20, 2004 | 09:23 PM
RICHRAD's Avatar
NEW as in " a brand new posi"? or just a NEW modification?
Old Aug 21, 2004 | 08:58 AM
DoBeR's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Transmission: 4 Spd Auto
You might find those gears a little too low for your 305. It will make a big difference in gas mileage. Just make sure you get the proper driven and drive gears to correct the speedometer.
I just went from 2.77 to 3.27 and while its not a huge jump there is definately a difference and its great!
Old Aug 21, 2004 | 12:14 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
The 3.73s are a bit much gear for the L03 but you will enjoy the change in acceleration.
3.73's weren't original to 86 except for a very few rare L69s so verify before you buy.
Old Aug 23, 2004 | 04:52 PM
ThraxXx's Avatar
Well its not a new rear end from a store. My buddy has it in his basement. It came from his dads old camaro that was in a headon collision. They salvaged what they could and scrapped the rest. He said the rear end has brand new brakes and the gears were just swapped in.
Oh and something else I wanted to add...what is this driven gear thing that you are talking about? Will the 3.73 trow off my speedo that much?
Old Aug 23, 2004 | 07:36 PM
leozimm's Avatar
Car: 91 Z28 Vert
I've been told that you can re-gear the transmission.....should be just a little piece that slides out and you can replace it with a new one from GM. I need to do this also since I just swapped out my drum/2.7x rear to a disc/3.2x gear.
I don't know the official name of the part.....but will go ask GM for it anyways. My description and gear ratio should get me the part to fix the speedometer issue of being way off.
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
hectre13
Aug 26, 2015 08:17 AM
