Shifter Slots wrong
Old Aug 23, 2004 | 05:59 PM
Z28cross-fire's Avatar
Car: '94 Z28
Engine: LT1 350
Transmission: 4L60E/A4
Shifter Slots wrong
i have an 83, with a big problem. i have a parking slot, but when it's put in park, it's really reverse, and the reverse slot is also reverse. i tryed messing with the arm and cable underneath the car but that didn't help much, does anyone have any ideas?/help?
Old Aug 23, 2004 | 06:05 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Loosen the nut attaching the cable to the manual shaft arm underneath the car. Put both the manual shaft and shifter into neutral, then tighten the nut.
Old Aug 23, 2004 | 06:23 PM
Car: '94 Z28
Engine: LT1 350
see that's the thing, there is no nut, it's a ball, with a pin over it, holding the cable on, and the cable isn't just a cable, it has an end with a hole, that slides over the ball, so it's really weird. does that help at all?
Old Aug 23, 2004 | 06:30 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Can you take a picture of it?
Old Aug 23, 2004 | 07:11 PM
Car: '94 Z28
Engine: LT1 350
here's what it looks like
http://img.villagephotos.com/p/2004-...56/tranny1.jpg
and this is the cable that adjust when you shift
http://img.villagephotos.com/p/2004-...56/tranny2.jpg
the black **** on the first picture is the pin, that's just a cap covering it.
Old Aug 23, 2004 | 07:17 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That nut on the bottom in your first picture is the one i'm talking about.
Old Aug 23, 2004 | 07:18 PM
Car: '94 Z28
Engine: LT1 350
yeah, that doesn't move, it doesn't even loosen. there's just a pin, and then the end of the cable that slides over it, i can't adjust it really. so i'm confused on how to do it.
Old Aug 23, 2004 | 07:23 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Is this on a 700R4 or a TH200C?
Old Aug 23, 2004 | 07:26 PM
Car: '94 Z28
Engine: LT1 350
i just got the car and haven't gotten a chance to look at it or anything. but it's a 1983 305 cross-fire injection with an automatic tranny. i wanna say it's a 200 but idk
Old Aug 23, 2004 | 07:28 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
4 speed overdrive or 3 speed?
Old Aug 23, 2004 | 07:32 PM
Car: '94 Z28
Engine: LT1 350
3 speed auto overdrive
Old Aug 23, 2004 | 07:35 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There was never a 3 speed overdrive offered in any platform by GM. Do you mean 4 speeds including the O/D?
Old Aug 23, 2004 | 08:11 PM
Car: '94 Z28
Engine: LT1 350
ok, it says PRND321 and automatic overdrive, i d k a whole lot about it right now, i've had it for about a week
sheachopper
Jul 31, 2019 11:27 AM
mcfastestZ28
Oct 5, 2015 07:12 AM
AUZ28
Oct 3, 2015 06:28 PM
ndndndnd
Sep 28, 2015 08:00 AM
