305TBI Way 2 Slow.why?
Car: 92Rs 25th ann
Engine: 305 TBI
Transmission: auto
Hey guys ok another problem lately my 92 305 tbi is having alot of problems lately i dont know what it could maybe i think tranny other than that thought i have no idea,please help.,ok first of all i noticed a few months ago that the tranny takes a while to shift say i get onto the freeway and floor it or even floor it for that matter it dont go nowhere it just reves up then goes and it redlines then jumps into the next gear all late,2nd thing is that i tried to do a rear end swap on it with a borg warner 9 bolt 3.73 posi disc to replace my stock drum one legger but it had problems and wouldnt work it needed to be calibrated,so i put the old one back in and now when i try to downshift it grinds in the back i have no idea whats going on,i know somethings up because it use to have more power than it has now and today my girlfriend wanted to race me and she beat me bad and she has a 04 4banger altima ,also i noticed if im at a light and try to put it in 1st it always stalls(auto) please help
Car: Badass 1991 Firebird
Engine: Screamin' 305 TBI
Axle/Gears: 2.73, 3.42's waiting to go in!
Hi, I'm no expert but I could suggest a couple of things. There are some guys on this site who really know their stuff, so hopefully you will be hearing from them. In the meantime I will give my two cents...
Of course you probably thought of this, but check your tranny fluid, in Park, with the motor running and warmed up. Your tranny could use some work perhaps. And maybe a bit of Lucas Transmission No Slip while you are waiting. Just don't overfill--use a pump to draw out some ATF if necessary. Ever changed the ATF and filter? I've heard it's a good idea, might even help.
Next, I would inspect your rearend install, make sure everthing is lined up right. I've never changed a rearend, so it's hard to say what has gone wrong, but something ain't right with the reinstall. The 3.73 rearend should have worked, so I would say, take out the one that's grinding, and do what you need to for the 3.73 to work. Then baby the car until you get the motor modded a bit to handle those gears. And be sure to tell your girlfriend that when your car is running right, you will blow her doors off.
Good luck, and hopefully one of the real mechanics on this board will post soon.
Car: 82 Camaro
Transmission: TH-350
Axle/Gears: 3.08
Try replacing the vacuum modulator if it has one. You didn't say what tranny you have
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
If you havnt done so already check and re-adjust teh TV cable. Do a search for 'TV cable' and 'adjust' and that should bring up the correct way to do it. The method suggested by most repair manuals wont work with an older cable that doesnt hold as well as it used to.
Dont know about all the rear end problems. You can always use the 9-bolt and jsut get new speedo gears later. Theyre not too hard to get to and change, although the pinion gear on the output shaft looks like it might be a pain to get off. The PBR brakes (if equiped) will work ok with the stock master cyl. and prop. valve but the braking force will be reduced to the rear and the pedal will have more travel. In real life Ive found that the brakes work ok and all four tires will lock up jsut fine in a panic braking situation
. Thread
Mike92
Nov 2, 2000 05:14 PM
