t-56 swap help and guide needed
Old Aug 24, 2004 | 02:50 AM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
ok...im ready for the install ive never installed a clutch b4...i need basic insturctions how to put on a clutch and and connect the clutch fork to throw out bearing... and put in the pilot bearing... i have a alignment tool...
also anyone have a pic of what part to cut out for the auto trans braket?? alot of pics would help...for pedal holes
and is there an resevoir i havet o buy for my brand new master cyl
Old Aug 25, 2004 | 08:52 PM
SLOWFIVEOH's Avatar
Car: 82' Z28 IROC Clone (SOLD)
Engine: 355
Transmission: Built TH-350
Axle/Gears: 3.73 Moser 12 bolt
Clutch installs are pretty easy,Slide the alignment tool into the pilot bearing in the motor, spline the clutch on, put the pressure plate up and bolt it into place and remove alignment tool. Throwout bearing, goes on the little collar. the whole collar clips onto the fork after you slide the collar over the shaft! Hardest part of the job is gettin the tranny in and out by far!
Old Aug 26, 2004 | 01:20 AM
porkyzilla's Avatar
Engine: 5.7tpi 350,
do you have a pic of what a throw out bearing looks like... my centerforce clutch dual friction for lt1 was supposed to come with one...
Old Aug 26, 2004 | 05:43 AM
SLOWFIVEOH's Avatar
Engine: 355
I dont know what the centerforce looks like, Im just goin on basic clutch knowledge. Should be an O shaped bearing one side should be flat and the other should have a cruve in it to contact the pressure plate... Its prolly about An inch and a half across...Maybe
Old Aug 26, 2004 | 06:46 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The CF DF clutch for LT1 has the throwout made into the center of the clutch at the factory. It's not a separate piece.
IROCZ1989
Jan 24, 2016 03:55 PM
jharrison5
Aug 19, 2015 05:53 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
cRoe4
Aug 7, 2015 08:46 PM
