89 Camaro rs build up
Old Aug 28, 2004 | 04:33 PM
FndmntlsOfPimpn's Avatar
Car: 87 Formula
Engine: 350 tpi
Axle/Gears: Stock 9 bolt
Hi im new to the boards i just purchased a 89 camaro rs 305 5speed with t tops its has a 10 bolt rear end in it and im building a 350 i have at home for it this winter im gonna be running around 425-450hp andwas aondering what upgrades i should do to the trans to amke sure it can handle that much power and be drivin to the track and run it on the weekends im going to tighten up the limited slip in the rear end so its tight enough that it dosent ever slip (my dad did the same in his chevelle) and run a 3:42 or 3:73 in the back but ould any one help me on what i shpould do to the trans and any sites i could find parts on thanks
Old Aug 28, 2004 | 09:41 PM
DSmith's Avatar
Car: 1989 Camaro
Engine: 383
The stock T5 trans will handle more than most people give them credit for if you don't just dump the clutch at high rpms or ****** it into gear like I am bad about doing but the best way to make sure it will stay there is to rebuild it with G-Force gears[URL=http://www.g-forcetransmissions.com]
Old Aug 29, 2004 | 05:17 PM
Car: 87 Formula
Engine: 350 tpi
ok thanks sould i jus spend the money to do a t56 switch how much hp are those good for stock?
Old Aug 29, 2004 | 05:58 PM
DSmith's Avatar
Car: 1989 Camaro
Engine: 383
I don't know anything about the T56 maybe someone else will step in with some info.
Old Aug 29, 2004 | 06:55 PM
nsimmons's Avatar
twin turbo lingenfelter vette uses the t56, vipers use the t56..you chasing vipers?
Old Aug 29, 2004 | 07:10 PM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
But the Viper spec T56 has quite a few things different then an LT1 F-body T56 that people are used to swaping into our cars.
Old Aug 29, 2004 | 08:21 PM
Car: 87 Formula
Engine: 350 tpi
haha good point wuts it take to do the t56 swap liek a parts list ima do a search im sure theres sumthin on this site already about it but is it worth it to do that or build my t5?
Old Aug 29, 2004 | 08:41 PM
nsimmons's Avatar
semantics...fine..650hp corvette?
Old Aug 30, 2004 | 11:26 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
650hp corvette?
With viper guts.
Old Aug 30, 2004 | 12:20 PM
nsimmons's Avatar
jesus people..the lt1 t56 is officially rated at 450ft lbs, which everyone and their dog knows is conservative. the point is he wont break it.
If you want to get really technical the viper box is rated at 550. Thats less than the vette makes, which just shows the numbers are conservative.
Old Aug 30, 2004 | 07:06 PM
Car: 87 Formula
Engine: 350 tpi
ok so should i build up my t-5 or swap a t-56 whats gonna be more cost effective mind you im a 16 year old kid
Old Aug 30, 2004 | 07:41 PM
nsimmons's Avatar
your 16? will this engine really have 450hp? have you driven a 450hp car? If your going to beat the snot out of it at the track go with the t56. Its cheaper, and a better solution than upgrading the t5
Old Sep 4, 2004 | 11:05 PM
klumb15's Avatar
T56 definately.....all i know is you better learn how to respect that car...i'm 17, and it doesn't take much to spin em out into a tree or something....450 is a bit much for a kid, and rather unpractical i might add..
Old Sep 5, 2004 | 10:54 AM
Car: 87 Formula
Engine: 350 tpi
well my dad has a 68 chevelle with a 475hp 396 he allows me to drive it from time to time (with him in the car of course) but i kno what that kind of power can do i plan on only really lettin it loose on the track but i work 2 jobs and i paint cars on the side so i have enough money to build the engine but thats gonna take about all i have atm im going to call around and see who around here has a t56 and see what they want for it now ive heard a few different things on how easy the swap is is there anyone that has done the sawp? if so how easy\hard is it? thanks for all the advice guys
Vintageracer
Jan 10, 2020 05:33 PM
italiano67
Dec 11, 2016 09:21 AM
86camaroman201
Aug 19, 2015 04:52 PM
GVMV
Aug 16, 2015 08:01 PM
sreZ28
Aug 14, 2015 07:48 PM
