Lock bolt broke. Now what?
Old Sep 4, 2004 | 11:00 AM
camaroman_83's Avatar
Car: 1983 Camaro
Engine: 305 4bbl
I went to take the lock bolt out of my rear and when it came out it was boke, so part of it is still in the pinion shaft. I wanted to change one of my axle seals because it's leaking a bit, but can't now. Any suggestions on how to get the bolt out? Has this happened to anyone before? Thanks!
Old Sep 4, 2004 | 11:08 AM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
How much of it is broke off? If the threaded part of the lock bolt came out than you can probably just get a magnet (the kind you buy at auto parts stores that extend) and get it out that way. Good luck!
Old Sep 4, 2004 | 11:34 AM
Car: 1983 Camaro
Engine: 305 4bbl
So the whole bolt isn't threaded? I know i got at least 1/2 inch of the bolt out. I'm not sure how much more is in there. I'll try getting a magnet though. Thanks.
Old Sep 4, 2004 | 01:52 PM
Benm109's Avatar
Engine: 305 TBI
If I remember correctly, the whole bolt isn't threaded. What kind of rear do you have, a 9-bolt or a 10-bolt?
Old Sep 4, 2004 | 02:10 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
if he has the lock bolt it is a 10 bolt, 9 bolts don't
Old Sep 4, 2004 | 02:24 PM
Benm109's Avatar
Engine: 305 TBI
Oh OK. I've never worked on a 9-bolt before so I didn't know. You learn something new everyday .
Old Sep 4, 2004 | 04:05 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
What I did when this happened to me:
Sprayed lots of WD-40 into the hole to 'thin' out any remaining axle oil, then used a small magnetic-tipped screwdriver to turn the rest of the pin out. Keep turning and jiggle it back and forth and it will eventually come out. Just a very little bit of thread was holding it in...
Old Sep 5, 2004 | 11:11 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
My old axle snapped at the first thread below the bolthead... so I got a junkyard axle.
Old Sep 5, 2004 | 01:09 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
I've broken a couple myself, and had quite a few come into the shop already broken, and they always seem to break right where Pete's did......at the very lat thread. Most of the time they'll turn out easy enough.
It helps to move the crosspin back and forth a few times before you try to take the bolt out. Sometimes you need a small hammer to help loosen it up.
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Linson
Nov 12, 2015 08:09 PM
gixxer92
Sep 1, 2015 04:32 PM
