No Overdrive
Old Sep 2, 2004 | 12:42 AM
vanceh's Avatar
No Overdrive
I recently changed the oil in my 700-R4 transmission on my 87 GTA after sitting on blocks for 6 months. Before putting the car on blocks the tranny shifted fine including going into overdrive. After replacing the transmission oil it will no longer shift into overdrive, all other gears shift fine. I just noticed I filled the tranny with Valvoline Dexron III Mercon oil, the manual calls for Dexron II. Could there be a difference in the oil weight causing Hydraulic pressure issues preventing it from automatically shifting into OD?
Or are the two oils compatible and this might just be a simple TV cable adjustment fix?
Thanks,
Old Sep 2, 2004 | 01:35 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
All versions of Dexron are compatible with earlier versions.
Prodigious
Nov 7, 2020 09:23 AM
1992Z28!
Nov 19, 2015 07:33 AM
mcfastestZ28
Oct 5, 2015 07:12 AM
wisemanz28
Sep 20, 2015 01:26 PM
84 TA NV
Sep 6, 2015 08:02 PM
