Need help installing 700r4 lockup kit
Old Sep 3, 2004 | 05:00 PM
BuiltZ28's Avatar
I'm installing the brake switch lockup kit from bowtie-overdrives into my 1987 700r4. My question is there are 2 presssure switches on the valve body. Which location of the 2 do install the pressure switch from the kit into. and what about the other pressre switch? What does it do?
Btw I have emailed bowtie overdrives numberous times about this and have received no response, there phone number does not work. What lousy service.
If anyone can help thatd be great
Old Sep 3, 2004 | 05:06 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It should probably go into the location of the 4th gear clutch switch in the diagram below. The other switch can be disconnected and left, or you can remove it and install a pipe plug.
<img src="http://www3.telus.net/~crussel/tcc_wiring.gif">
Old Sep 3, 2004 | 07:23 PM
BuiltZ28's Avatar
Thanks for the info and a great diagram. Is anyone else sure of the location before i go on and rig it all up
Old Sep 3, 2004 | 07:30 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I don't know anything about the bowtie overdrives kit, but if it's like 99.44% of the kits out there that's where it'll go.
Old Sep 4, 2004 | 04:37 AM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Yup, Apeiron and others helped me out with this same project. That is where the switch goes.
camaro11j
Sep 19, 2018 08:49 AM
italiano67
Dec 11, 2016 09:21 AM
toronto formula
Nov 10, 2015 06:17 AM
TreDeClaw
Aug 14, 2015 06:58 PM
drathaar907
Aug 6, 2015 04:20 PM
